To20
Mike Williams
11-01-2000 05:56:21
I have the opportunity to buy a To20. I have 60 acres of land and the tractor would be used mainly to maintain the roads, dig some post holes for fence, and some bush hogging. The motor has been recently overhauled. I know very little about the To20, so I'm asking for input. Is the tractor good for what I want to use it for? Are they pretty reliable? I would appreciate any opinions.
Thanks,
Mike Williams
Mike Williams to Tex
11-13-2000 11:00:17
 Re: To20 in reply to Mike Williams, 11-01-2000 05:56:21
Tex, thanks for the information. Do you happen to know where I could get such a thing as the override clutch? I am also looking at the 'Zanethang' to make sure everything stays level. I will keep you informed of my decision. Sure is leaning that way.
Again, thanks for your help.
Mike Williams
Mike's overrun clutch frm Tex
11-14-2000 18:29:16
 Re: Re: To20 in reply to Mike Williams to Tex, 11-13-2000 11:00:17
Yeah, Mike, the so-called overrun clutch is about the size of a soup can with a second PTO shaft sticking out the back end. There is an internal ratchet mechanism which allows the outer PTO to turn faster than the tractor's PTO shaft. There is no external manual control, fully automatic inside. I imagine every tractor dealer, maybe even NAPA carries them. Just be sure you get the right size. It is well worth the money if you do any bushhogging at all. Goiod luck and keep us posted! Tex
Tex Ferguson
11-10-2000 17:40:29
Mike! I've had a '49 TE20 for 5 yrs, doing the things you mentioned, and it is a great little worker. Mine blows a steady stream of blue smoke and likes to have the oily carbon chipped off the sparklers occasionally, but it probably hasn't seen an overhaul in 20 yrs or more. I don't think you'll be disappointed, especially since your prospect has had a recent overhaul.
One caveat on the PTO: when the PTO is engaged(shift lever on left side of transmission has two positions: engaged and disengaged), it turns when the clutch is released. A "live" PTO is one that has a separate clutch. Problem is when a bush hog is revved up, even with the clutch pedal down, the momentum of the blades continues to turn the PTO shaft and with it, the transmission, and this causes forward motion. I guess I never checked it, but I suppose you could travel 20 or 30 feet on the energy of the blades. As you can imagine, this is very hazardous to the radiator if you have as much brush on your place as I have, or if you're working around buildings or fences. The remedy is a $60 overrun clutch, available from most tractor dealers, which attaches to the PTO shaft and acts as a ratchet, allowing the implement driveshaft to turn faster than the PTO. This means you regain control of the transmission and forward motion of the tractor! A highly recommended addition if you want to run a bushhog.
Good luck, and be sure to post back your decision!
Tex
JW
11-07-2000 14:38:31
GO FOR IT
I HAVE HAD A TO-20 FOR 10 YEARS
I REBUILT THE ENGINE 5 YEARS AGO (DIDNT REALLY NEED TO BUT I THOUGHT WHAT THE HELL)
ALL PARTS WERE AVAILABLE AND LAST MONTH I DID THE BRAKES AND THE PARTS WERE ALL HERE IN 3 DAYS (SHOES, COLLARS, BEARINGS, ETC.) IT'S A GREAT TRACTOR AND ILL TAKE A HARRY OVER A HENRY ANY DAY.
JEFF
Mike Williams to JW
11-13-2000 11:02:01
 Re: Re: To20 in reply to JW, 11-07-2000 14:38:31
JW, thanks for the information. I am really leaning toward getting the TO20. I really appreciate all your information.
Mike Williams
eric
11-01-2000 12:19:28
The TO-20 has about the same rear end as a 8 or an 9n Ford the are some differences. This tractor more than likely has a Conntinetal engine in it, they seem to hold up pretty good. It does'nt have live pto or hydralics.
Mike Williams
11-06-2000 06:41:45
 Re: Re: To20 in reply to eric, 11-01-2000 12:19:28
Eric, thanks for the information. Do you own a TO20? If so, is it reliable? Do you think it could handle the items I want to do on my land? I appreciate your input.
Thanks, Mike Williams
