suddenly quit starting
jd/mo.
09-10-2006 14:03:58
I guess it's an electrical problem, I searched the archives, couldn't satisfy myself with what I found.
I was welding on my disc, which was attached to the to-30 with the 12v conversion. I raised and lowered the disc severa ltimes to remove and replace the blades and axles. Never had a starting problems in the 2years I've had my Fergie, but when I finally finished working on the disc, and got ready for some work...she refused to start.
Turns over just fine. Took the air breather pipe off the carb and gas ran out the side tube ( small amount), removed and cleaned the settelen bowl, gas seems to be flowing fine. pulled the coil wire from the distributor and held it against the engine block and got a weak blue colored spark, pulled #1 spark plug wire and grounded against block...no discernable spark.
I may have left the ignition key on at one point while I was welding on the disc.
Any information or help is greatly appreciated. I'm thinking, coil, condensor, points, and probably a new electronic ignition,but want to find the problen first. Shes alway been a reliable friend.
Thanks again jd
Jerry/MT
09-10-2006 14:36:42
 Re: suddenly quit starting in reply to jd/mo., 09-10-2006 14:03:58
The fact that you have a weak blue spark at the coil high tension lead says that your primary ignition circuit( from battery, through the key switch through the coil, through the points.) is the problem. Start by making sure all the connections are clean and tight.Then check the voltage on the battery side of the coil.It should be near 12V. If it's not than check the voltage on both sides of the key switch with the key on. Again you should have near 12 V at each position. If not, the key switch may be bad or the connections may be. With the points open you should see 12V at the distributor side of the coil. With the points closed, my guess is that you should see 5-7 volts at the distributor side of the coil. If it's lower, your coil may be bad.
Look at the points and see if they look burned and then check the gap(0.022")but if the points are worn you may not get the right reading. So file 'em and reset them. If that doesn't work, you might consider ptting new points and condenser.
Were your plugs wet with fuel when you tried to start? You should not have a lot of fuel dripping from the carb air intake unless you tried numerous starts in sucession.
Do these checks systematically, one step at a time, and right down the results for later analysis. Come back and tell us what you found.
jd/mo
09-11-2006 06:07:15
 Re: suddenly quit starting in reply to Jerry/MT, 09-10-2006 14:36:42
Jerry thanks for the valuable info. I knew there was a progression for checking this problem but I didn't know the steps, now I do, thank you.
The fuel from the carb was due to several tried starts, and since my tractor is in my place in the country, it'll be a couple of day till I can get back with you, but I'll let you know the results.
Thanks again
jd
Jerry/MT
09-11-2006 10:34:51
 Re: suddenly quit starting in reply to jd/mo, 09-11-2006 06:07:15
jd, I have to tell you that I think you're one of the few guys to check the ignition system when they have trouble starting. The majority of the people think its the carb when in fact the primary ignition circuit is the problem nine out of ten times. The engine in resonable mechanical condition needs three things to start and run;a strong, fat, bluish spark at the right time and the right fuel/air ratio. Remember this axiom because it's the basis for for trouble shooting the "no start" and "poor running" problems.
jd/mo
09-11-2006 14:00:28
 Re: suddenly quit starting in reply to Jerry/MT, 09-11-2006 10:34:51
Thanks jerry!
