TE20 PTO seal
Robert E Barret
09-09-2006 02:57:54
My PTO was leaking ,so i decided to replace the seal. When i pulled the shaft i could NOT find anything that looked like a seal.. Looking at the input side of the shaft i see a bearing. Looking at the output side of the shaft i see a bearing.I pressed a new seal on the transmission side of the shaft as to where it rest against the bearing clip.Everything fits well , but the seal lacks a quarter inch being flush. . Am i in the right direction or best start over?Any help appreciated
Robert E Barrett
09-09-2006 15:52:01
 Re: TE20 PTO seal in reply to Robert E Barrett, 09-09-2006 02:57:54
Thanks Jerry, Id best pull it out and start over .
Jerry/MT
09-09-2006 11:42:36
Per the Ferguson Parts Manual, starting with the PTO hub that bolts to the rear axle casting, the order of parts is:
sleeve retaining snap ring, oil seal sleeve,
oil seal,bearing retainer snap ring,
bearing assembly, bearing retainer snap ring.
This is common to the T0-20,-30, Ford 9N & 2N, TE-20, & TE-A20.
