crankcase oil
Harry F
09-08-2006 19:05:38
New to the forum- bought a TEA last winter and changed the oil this spring. My question is, the oil still is not dirty after weekly use. I initially thought this was good but the more I think about it - there may be a problem. I checked the crankcase oil today and it seemed to be as clear as when I put it in. Anyone have any ideas? Harry
TexMac
09-08-2006 19:43:46
 Re: crankcase oil in reply to Harry F, 09-08-2006 19:05:38
Do you have oil pressure? If so, I wouldn"t worry. I have a TO30 I bought back in "93 with a rebuilt engine (really just rings and inserts I suspect). I maintain just over 14 acres, mowing, disking 1ac garden, a little dirt work and tree pulling. Tractor runs at least once a week all year long. I only change oil and filter once a year (Valvoline 30W Racing and MF filter). Looks dark when drained, but clear on the stick. I expect all my engines to do that, but I do maintain them religiously for tuning and use good gas.
Harry F
09-08-2006 21:47:56
 Re: crankcase oil in reply to TexMac, 09-08-2006 19:43:46
TexMac, Oil pressure runs at about 25 when completely warm. You certainly helped calm my fears. The tractor runs like a top, just that I have never had a machine run so clean and hoping I,m not missing something. Harry F
TexMac
09-08-2006 22:38:29
 Re: crankcase oil in reply to Harry F, 09-08-2006 21:47:56
Sounds good to me. You can tell a lot whenever you change oil next. Use a clean drain pan (I get a cheap plastic one at the Dollar Store). If you are wearing anything, you"ll find particles in the oil. Sounds like maybe someone rebuilt it or at least flushed it before you got it. That pressure sounds like very little bearing wear if at low rpm. Mine goes down to about 10 at warm idle, but I know I once did some damage to mine when the pin sheared on the oil pump. Even though my engine is different, most of those old tractors run about the same oil pressures. Keep it tuned and clean and you should get lots of use and fun out of it.
Harry F
09-09-2006 10:46:22
 Re: crankcase oil in reply to TexMac, 09-08-2006 22:38:29
Thanks, TexMac.
