steering
george henson
09-02-2006 23:09:47
i have a massey ferguson 175 tractor. my problem is that the steering wheel has alot of play in it. any comments welcome. thanks!
Bill Brox
09-04-2006 02:02:39
 Re: steering in reply to george henson, 09-02-2006 23:09:47
Hi there. The 100 series tractors do get a lot of play in the steering. The reason for this is lack of lubrication for the most part. No one cares to open the grille to grease what needs to be greased in there.
Now, you need to find out where the play is. You need a friend for that, one that can sit in and move the steering wheel and you walk around looking for the play.
Often it sits in the front of the tractor, but it can also be the steering box. The steering box have an adjustment screw on the right side. Loosen the nut and tighten the screw with a large screwdriver, but that only works if the play is in the steering box. If tightened too much you will feel the steering wheel is hard to move, then you need to back off the screw and retighten. It is supposed to be a tiny little slack there. I have a MF 50 Industrial, same setup as your MF 175, and it had something between 1/2 to 3/4 round of play. I had to bring it home on a trailer. Had to replace everything in the front, all the bushings.
Let us know what you find.
Bill
