marlowe/John(UK)
JD Ga
09-01-2006 14:53:33
I know you fellas have answered the question a million times about setting up a bush hog on a tractor w/o position control,so I really hate for you guys to do it again. So instead could you tell me where I can find it on this message board, maybe on a previous post. I've looked everywere and cant find it. Many thanks.
JD Ga
09-01-2006 18:56:27
 Re: marlowe/John(UK) in reply to JD Ga, 09-01-2006 14:53:33
This helps alot. I appreciate it too! Many Thanks.
Does this help?
09-01-2006 15:13:04
Here ia what was posted several months ago by marlow.
Brush Hog Set-up
I have sold and serviced hogs for years and see this all the time. PLEASE don't take this wrong but it's a real common mistake that they are not being mounted right. I know what your thinking how hard is it to put a hog on a tractor and go cut some grass�but�your hog has a tail wheel right? Your tractor has 2 lower lift arms right? Set your hog on a 4x4 so it is level lower your tail wheel so it's on the ground. Now put your tractor on but �DON'T� hook up the PTO. With tractor running put the 3pt control lever in the middle of the range and turn your top link so it will get longer and you will feel your 3pt. raise just a little and the stop but when you make the top link long it will raise a little more that because the control piston under the set is being pushed in and that makes you 3pt. lift until the pressure is released. With a little fine tuning and a little setting of the tail wheel up or down for the height of cut you want your hog will cut at the height you want. If you have ANY questions call me I will help you set it right 1-920-446-3296 your hog should not be hanging on the tractor when you�re cutting but riding on the tail wheel and the 3pt. at a set height and that is controlled by your top link. Good luck and if you need help call
