MF's reverse gear
jiskies
08-31-2006 19:03:33
Just had a question about putting MFs into reverse. Have a 180 and 255 and both are hard to put into reverse. Are there problems with reverse gears on massey fersugons?
thanks jeff
John (UK)
09-02-2006 10:08:48
 Re: MF's reverse gear in reply to jiskies, 08-31-2006 19:03:33
Make sure that you don't have too much free play in the clutch pedal, too much play means that the clutch will not be able to free the drive plate enough to allow you to engage gear cleanly. Usual setting is 3/8 between the footrest and the pedal. Don't take all the play out to make it work though or you will wear the thrust bearing and the fingers on the clutch, if you have to take all the play out to get it to work then the clutch needs resetting or overhauling.
Boss Hog
09-01-2006 04:41:56
It helps if you come to a complete stop before you shift it out of the forward gear.
