Question on coil wiring
John (TR)
08-26-2006 20:25:31
Was looking at my new purchase TO 20 and noticed the coil only has the high voltage lead and the wire to the dist. I looked up the wiring schmatics on Ferg enthusiast site and they show the coil connected back to the starter switch.
Its 6 volt and runs although misses and I know I have many other things to rule out. SHould I be concerned about the missing wire on the coil?
Thanks
John
John (UK)
08-27-2006 06:05:31
 Re: Question on coil wiring in reply to John (TR), 08-26-2006 20:25:31
It must be getting power from somewhere as it wouldn't run. I would say look again and you will find it. The feed for the coil is from the switch but it could be taken from anywhere there is power just to try it.
Ray,IN
08-26-2006 23:14:42
IF the wire from the ignition switch to the coil is missing, how is it getting current? The coil is getting current from a hot(in this case negative) wire or the tractor would not fire the plugs. The ignition switch breaks the current flow shutting off the engine.
