TEA 2085 timing
chuck130
08-24-2006 05:58:19
Engine number is SC67238E, My servive manual is ambiguous. Can anyone confirm that the timing is correct when the following 3 conditions co-exist:
1. Flywheel 0 degree marking is aligned with scribed line in starter hole;
2. Scribe line on cam sprocket aligns with scribe line on crankshaft sprocket;
3. No. 1 (front) piston is at TDC.
Note that my cylinder head is not installed at this time.
Thankyou
John (UK)
08-24-2006 08:09:17
 Re: TEA 2085 timing in reply to chuck130, 08-24-2006 05:58:19
If you put a rod into the timing hole below the starter that will give you the correct setting, otherwise everything is ok. Just make sure that the valves on number 4 cylinder are "rocking" at this point though. I have sent you the correct way to time this engine by email..John
