TEA2085 Valve springs
chuck130
08-22-2006 08:53:41
Bareco provided me with springs that do not have the same specs as my manual:
Freelength is 2.00" vs 1.787"
Fitted load is 60lbs vs 38 lbs.
Anyone know for sure if this will be a problem from a performance perspective?
Thanks
John (UK)
08-22-2006 14:40:43
 Re: TEA2085 Valve springs in reply to chuck130, 08-22-2006 08:53:41
Sparex do a spring to replace the original, part # S61906 (825186M1)(MF)
chuck130
08-23-2006 04:36:54
 Re: TEA2085 Valve springs in reply to John (UK), 08-22-2006 14:40:43
Can you confirm that the Sparex part has the same specs as original? Bareco tells me that these longer springs will work. They also said, of interest I think, that some TEA's, repeat TEA's were fitted with Continental engines and that this spring will fit all Fergusons without Continental engines. Perhaps they have it backwards.
John (UK)
08-23-2006 05:29:27
 Re: TEA2085 Valve springs in reply to chuck130, 08-23-2006 04:36:54
No I can't confirm that the spec is as original. It would not be a TEA if it had a Continental engine, that is the idea of the third letter, to tell you just what it is. If it had the Continental it would just be a TE. I wonder where they get these ideas from? It is possible that you can have a TEA fitted with a Continental engine as a replacement but not from the factory.
I must admit I have never heard of anyone complain about these springs from Sparex and they are by far the biggest supplier of aftermarket parts for the Ferguson now. What BareCo said was a bit confusing don't you think, they should have said that this spring is for the Standard engine only and not started confusing the matter with TE's and TEA's. I feel sure that these springs must have been tried and tested before, if there had been any problems they would have withdrawn them. I agree with Gerard though, the specs for the springs are incorrect, perhaps that is the nearest they can get without having a special one made, which would raise the price considerably. It would appear that they are safe to use from the information that we have.
gerard
08-22-2006 14:05:39
As an engine builder of all types over many years, I wouldn"t use them. Although cam lift on these vehicles is hardly "high lift" I"d still be concerned about coil binding & valve stem stretch / failure due to massive loading increase. Don"t forget this loading goes through the whole train down to the cam lobes / followers.
chuck130
08-23-2006 04:39:27
 Re: TEA2085 Valve springs in reply to gerard, 08-22-2006 14:05:39
Gerard, I tend to agree. I'll follow through with Sparex. I'll pursue Bareco and try to find out why they are marketing parts for applications which they are not designed.
