ROCKER ARMS
TOM COLVIN
08-16-2006 10:08:20
WHERE CAN I FIND ROCKER ARMS FOR THE TEA20, 1951 MODEL? ALSO THE GOVERNOR SHAFT SEAL?
THANKS,
TOM
John (UK)
08-16-2006 11:28:40
 Re: ROCKER ARMS in reply to TOM COLVIN, 08-16-2006 10:08:20
If you take the seal out you should be able to get one from a bearing and oil seal factor, you will need to replace the bearings too. The rocker arms are more difficult, try the Triumph sports car club site if you are in USA or Canada, the engine is very nearly the same. If it is just the heel of the rocker that is worn you could have them re-profiled.
TOM COLVIN
08-16-2006 13:26:34
 Re: ROCKER ARMS in reply to John (UK), 08-16-2006 11:28:40
WHERE WOULD I RE-PROFILE, A MACHINE SHOP MAYBE?
I HAVE A GUY THAT SAYS HE CAN BUILD THEM UP AND GRIND THEN BACK DOWN TO SIZE. I THINK HE WILL WELD ON THEM TO BUILD UP.
TOM
John (UK)
08-16-2006 13:44:16
 Re: ROCKER ARMS in reply to TOM COLVIN, 08-16-2006 13:26:34
A machine shop should be able to do it or one that specialises in engine rebuilds. He could add weld to them and grind them back to shape, they should work ok with that. Have they worn due to an oil shortage in the top end, this could be due to camshaft rear bearing being worn or just generally low oil pressure, that would possibly require a new Rotor Pack for the oil pump.
