Before I had posted that my TO30 was not running well under load, nearly stalling, or stalling sometimes. I couldn't mow more than 8-15 minutes before this would happen.1. I replaced the coil. No change. 2. I inspected the wires, cap, rotor, plugs, all seemed fine. I verified there was gas, yes. 3. I ordered a carb rebuild kit from ytmag.com. I rebuilt the carb. 4. I physically removed the fuel line, the sediment bowl assembly and blew them out with compressed air. I mowed for 1 hour, 30 minutes of it was in high grass and no stalling, or any other problem. So I guess I am all fixed up. One thing though, I had to re-use my fuel nozzle as the one it came with did not match mine. All the other parts matched. Also, there were parts leftover from the carb kit. But everything I took off was replaced by a new part sans the fuel nozzle. Oh well. It runs now. BONUS: the throttle range works fine now. Before, it seemed no to operate properly, surging high at times, and touchy. Now it uses the full range like I would expect it to. THANK YOU everyone for the help. I am guessing that the problem was fuel delivery. And/Or it could have been the condenser. Next Time I do a carb rebuild I will order just the needle/seat. All of my parts showed no wear or damage, but I replaced them anyway.
