TO-30
garry lee
08-08-2006 09:50:34
i'm posting for my cousin as he is in need of some help and parts. he has a TO-30 and believe he said this tractor has a continental gas engine in it. at any rate, his block is cracked and he is trying to rebuild this tractor and is looking for a block, but has been told my alot of folks that blocks cracking was a comon problem and he would have trouble finding a block, so i told him about the help i have gotten from folks here and decided it was worth a try. so if anyone can help please let me know.
thanks
Gary
Jerry/MT
08-08-2006 12:54:21
 Re: TO-30 in reply to garry lee, 08-08-2006 09:50:34
The TO-30 uses the Continental Z129 engine. If the engine has been seriously overheated the block can crack, usually between the cylinders. If you have a cracked block you have at least three choices;1) find good replacement block, 2) Find a machine shop/engine rebuilder that can furnace braze your damaged block, 3) Use tension rods placed in holes drilled through the water jacket and located between the cylinders to pull the cracked block together.(I guess there's a fourth, part the tractor out.)
I would recommend 2) because the process involved in furnace brazing stress relieves the block casting and then it's align bored to factory specs. I bought a remanufactured short block when my original engine was plumb wore out and I needed the tractor running ASAP. The block had been furnace brazed/aligned bored, etc. I have had it for 5 years with no problems and it's a working machine on my ranch.I have seen this proces used on a Case backhoe with similar results. Hope this helps.
