Tie Rod Boot Replacement - TO-30
K. E. Siladi
08-06-2006 18:40:39
Got another question about the front end on my tractor. This site advertises a tie rod boot assortment. The ball joints on mine (front and rear) are nice and snug but the boots are practically non-existent (dry rot I suppose). Has anyone ever replaced the boots? My service manual doesn't seem to even mention a replacement procedure. How difficult are the boots to replace?
RegoR
08-08-2006 12:39:10
 Re: Tie Rod Boot Replacement - TO-30 in reply to K. E. Siladi, 08-06-2006 18:40:39
Hi K.E.,
FWIW, I replaced the ends on my tractor a couple of years ago and the new rubber boots were only about a year old when they started to break down and fall apart. Inferior quality to be sure. If I do this again, I'll check to see if better quality ones are available...
Roger
K. E. Siladi
08-07-2006 17:27:55
John, thanks for the reply. The rear ones are off already due to the engine rebuild, and I have no doubt I'll be able to get the front tie rods off. 50+ years of grease and ?? made me wonder if I even wanted to touch them. Thanks to your advice, I'll be getting real dirty soon trying to replace the boots. Thanks again
John (UK)
08-07-2006 08:29:21
Quite easy to replace, hardest job is getting the joint out of the arm. to do that hit the arm with a hammer to shock the taper on the joint, it will jump out then. You could say they are a bit fiddly to fit, but with patience they are no problem.
