general question TO20
Hansi
07-30-2006 09:08:36
What is the lever next to the key ignition on the TO 20 used for? It has been puzzling my father for sometine as to what it's use is.
Bob (Australia)
07-30-2006 16:37:01
 Re: general question TO20 in reply to Hansi, 07-30-2006 09:08:36
third party image
John
Got curious about that "round thing" after taking the photo. Went back to look and see it is the end of the throttle shaft.
Seems an odd way to construct the throttle mechanism? Am I correct in assuming it was built this way possibly to accommodate a different type of hand throttle?
Bob
John (UK)
07-30-2006 17:25:54
 Re: general question TO20 in reply to Bob (Australia), 07-30-2006 16:37:01
All the throttles on the carburettor versions (same right up to 135)are like this, the round disc is part of the friction pad that holds the throttle lever in position. There is a spring on the rod at the back of the air cleaner that you can move along the rod towards the back of the dash panel, when you do this it applies more pressure to the friction pad. If ever you adjust it like this and it doesn't work you will find that the pad is hard and glazed, like a brake lining or it has disintegrated and is no longer doing its job. It would require replacement, the hard part is that you have to reset the governor linkage. I have the information you would need to reset it, so just email me if it is ever needed....John
Bob (Australia)
07-30-2006 16:29:09
third party image
This "lever"? As John says, bonett (hood) locking catch.
Unlocked:
John (UK)
07-30-2006 17:18:23
 Re: general question TO20 in reply to Bob (Australia), 07-30-2006 16:29:09
Bob, you are showing a TE Hood lock, he asked about a TO20/30 hood lock which uses a lever connected to a rod that locks both sides of the Hood at the same time. Just one of the small differences between a TE series and a TO20/30
John (UK)
07-30-2006 11:03:12
It sounds like you are describing the lever for locking the Hood down.
Bob (Australia)
07-30-2006 16:41:19
 Re: general question TO20 in reply to John (UK), 07-30-2006 11:03:12
Sorry about me "jumping the queue" with replies. Still learning how this bulletin board works.
I'd never presume to jump the queue on the Fergy supremo! :-)
John (UK)
07-30-2006 17:05:21
 Re: general question TO20 in reply to Bob (Australia), 07-30-2006 16:41:19
If you are referring to me Bob, I shouldn't let that worry you.lol....John
