Block, head or gasket
Rmiley
07-30-2006 06:53:09
TO-30 tractor runs good but has oil in water and bubbles in radiator. Could this be just a head gasket?
Rmiley
07-31-2006 02:32:04
 Re: Block, head or gasket in reply to Rmiley, 07-30-2006 06:53:09
Yes it has a cowling for the fan. It does not overheat and there is no water in oil,just oil in water.
Jerry/MT
08-02-2006 10:16:45
 Re: Block, head or gasket in reply to Rmiley, 07-31-2006 02:32:04
The reason the oil is in the water is because the oil presure is greater than the coolant pressure. The radiator cap holds the coolant pressure between 4 and 7 psi (depending on the cap) but in general, the oil presure is above 15 psi unless the bearings are really worn .
steve19438
07-30-2006 16:11:28
if the radiator does not have anti freeze in it add a gallon to it, if the anti freeze leaks into the motor oil the bottom of the block is most likely cracked.
Jerry/MT
07-30-2006 12:35:54
As John(UK) said, it could be a head gasket in the best of cases and it could be a cracked block or cracked head in the worst case. You'll have to pull the head to find out.
John (UK)
07-30-2006 11:08:48
Yes it could be just a head gasket but it could be a lot more, remove the head and find out. If it has been overheating it could have cracked something, is your radiator clear and have you got a fan cowl fitted to help draw more air through.
