TEA 2085
sticky clutch
ron bond
10-23-2000 10:47:57
The clutch on my TEA 2085 is sticky in that occasionally when in gear, it will not disengage when the clutch pedal is depressed. Also, it is very grabby on engagement and jerks before engagement is complete.I would like to know what I can do to smooth out the clutch operation and stop it sticking to the pressure plate - hopefully without doing a clutch job. At this time
I am holding the clutch of the pressure plate by
keeping the pedal held down to see if this helps.
ron bond
11-01-2000 05:48:27
 Re: TEA 2085 - sticky clutch in reply to ron bond, 10-23-2000 10:47:57
I received some good advice from bob in aus. Drill a hole in the bell housing and squirt degreaser on the clutch and pressure plate - this worked for him. Also, a friend told me the problem was that the TEA does not have a vent hole in the bottom of the bell housing. While this normally should not be required, it does allow oil to drain out of the bell housing thus preventing contamination of the clutch.
Taffy
10-25-2000 14:42:48
Have you tried adjusting the clutch pedal to get correct amount of free play.
Otherwise I suspect you will eventually have to remove the engine and sort it out.
Common reasons I've found on the tractors I repair are: oil leaking from rear crankshaft seal
oil leaking from gearbox input shaft seal
worn clutch plate/release bearing.
Not so good news but fairly easy to sort out if you have the time/funds.
