Marvel Shebler Rebuild Tip
Dave G
10-22-2000 17:39:03
I finally got the thing to give up fuel to the engine. After the first cleaning and rebuild, I couldn't get the carb to give up any fuel, so I disassembled it AGAIN. This time, rather than only using solvent and compressed air to remove dirt from the passages, I used thin copper wire to clean out areas that the solvent couldn't get.
I stripped stranded 10 ga. and 12 ga. wire and used the strands to gently push the passages clear. This removed quite a bit more goo than I ever expected.
I reassembled the carb and Presto! The ol' Fergie fired right up on her own fuel!
Hope this helps some others that had wrestling matches with rebuilding MS carbs. ~ Dave
ken
10-22-2000 19:29:55
 Re: Marvel Shebler Rebuild Tip in reply to Dave G, 10-22-2000 17:39:03
where did you get your rebuilt kit at and how much was it. Can you also tell me how to adjust the carb
