The other guys hit this one pretty good, I wasn't really going to reply, but... I'm here, so here it is... The TO uses the exact same 3Pt components as the N. I buy the 'el cheapo stabilizers at TSC, for ~$8-10 or something like that. They are listed as "Ford N stabilizers". I've bent a couple of them when used solo, I've learned my lesson and use them in pairs now (as they were intended anyway).I've seen adjustable stabilizers, they cost A LOT more. You don't need them if your brackets are installed properly under the axle, as one of the other guys said. And like the other guys said, if you kick your implement to get it centered (lift the implement a couple inches off the ground first so you don't break your foot) the other stay should go right on the end of the hitch pin. I recommend using both stabilizers for a heavy'ol 5' cutter, especially if you have any hills, or run on a grade where the mower may shift from side to side. Don't forget your over-run coupling, watch out for stumps, keep your radiator clean of debris, and HAVE FUN! George
