horsepower and torque
George in MI
07-20-2006 17:26:10
It is incorrect to think that you should run the engine at maximum torque. Torque and horsepower are two completely different kinds of measurements....like inches and pounds. Torque is a measure of twisting force. Work is measure of force (torque or otherwise) times distance. And power (or horsepower) is a measure of work per unit time. An electric motor which produces high torque at 0 rpm does no work and therefore produces no horsepower (if it does not turn).
The reason why a tractor might pull a plow or weight at a slower speed than a faster one is that the power required is less....not that somehow "torque" does the work at low speeds and horsepower does it at high speeds. For example, say it takes 20 hp to pull a plow at 8 mph. Then it will take only 10 hp to pull it at 4 mph.
So the advice to run the engine at an engine speed which gives maximum horsepower and select the gear which gives the right speed is exactly correct.
