You need a flaring tool to flare the steel line. You can rent them, or borrow them from several auto parts places. Auto Zone (if you have those in your area) loans them out for free. You can try using a plumbing flaring tool, instead of a steel line flaring tool, however, my experience is the plumbing tool (intended for copper) flares the line too wide and splits the steel line unless you are real careful. Take your existing fuel line to an auto parts place to match-up the correct ID. Don't ask for metal fuel line, they will look at you like you are insane. Ask for metal brake line, they will smile and be very helpful matching-up your line size, etc. (been there, done that). You can go with a bigger filter than the current line size, I would not recommend going smaller, or risk starving fuel to the carb. It's pretty common to see plastic disposable filters hosed into old N's and Fergy's... make sure you do a good job. If you get a leak, or the hose lets loose while your working, your gravity drain gas tank will contribute to a Fergy Fireball!! ... Hence the use of steel lines in the original. George
