Dearborn loader Hyd cylinder upgrade
Bruc
07-15-2006 22:28:38
Anyone ever change the side loader cylinders to a dual acting cylinder set up so the bucket can get some down force?
Thanks much!
Bruce
John (UK)
07-17-2006 06:34:11
 Re: Dearborn loader Hyd cylinder upgrade in reply to Bruc, 07-15-2006 22:28:38
There is no reason why you can"t do that, just make sure that the loader frame is strong enough to take some down force though, it may only be braced for lifting. You must also remember that you can"t take too much oil out of the tractor to operate the loader, something else to consider, about 2 gallons at the most. Make sure that you return any oil from the loader into the Hydraulic section of the tractor NOT through the filler plug on top of the gearbox or you may get oil starvation of the Pump.
Bruc
07-17-2006 08:17:09
 Re: Dearborn loader Hyd cylinder upgrade in reply to John (UK), 07-17-2006 06:34:11
The Dearborn in question is a model# 19-21 which has been updated to a front pump and a hyd. tilt cylinder on the bucket. The wife desires it to also have some down force on the bucket in order to utilize it somewhat more effectively. I believe when I locate the dual acting cylinders, I shall lose some of the height to which the bucket can be raised in order to be able to push it down. I was hoping that someone had already done this procedure and could possibly give me the specifications for the cylinders that they had installed.
Have a good one!
Bruce
9N28123 TO34662
