Previously: I have posted previously a month or two ago about my new tractor ('52 TO30). I have been quite busy (who isn't, right?) and have had barely any seat time on her. Previously I had asked about position control, check chains, and engine not running right (throttle governor, etc.). Since then I have mowed twice with it and have also gotten the operators manual and the dealer shop manual. BTW the check chains are working GREAT! Thank you for all the advice there.Today: I poured in fresh gas, got on the tractor, turned on the fuel, hit start, little choke, started right up with no fuss. I mowed for 20 minutes before it started to act up, which was what it did before as well the last two times I mowed. Anyway, after 20 minutes it started acting like it was going to die. Running up and stall, run up and stall, but stayed barely running. I let it cool and it ran for a few more minuted, then same thing. I got so mad! I wish I could keep a cooler head when my machines give me trouble. This time when it died it wouldn't even turn over to restart. Then I started thinking about the ammeter how it is always at dead zero. So I looked at all of the wire connections, everywhere. The wire from the 12volt alternator was fine all the way to the ammeter. Then I noticed: The wire from the ammeter to the terminal was not connected to anything. (the terminal where the battery wire connects to the starter -- is that a relay?) So my brain says to me: how will the battery recharge if the wire from the alt is basically disconnected? Obviously I have drained the battery and that is likely why it won't turn over. So here is my question: Could that be why my engine has been running rough? Will my tractor run on a dead battery? If it will run on a dead battery with the alt disconnected, then I am on to chasing fuel and ignition problems. I am sorry for my ignorance, I am not a very good troubleshooter. And thank you in advance for any replies. Chris
