TO20 rear differential
Casenut
07-15-2006 16:56:14
I need to replace the rearend housing and differential on my TO20 serial #54206 Is the housing or the differential the same as the 8n, 9n or the TO30?
Salty
07-18-2006 17:31:21
 Re: TO20 rear differential in reply to Casenut, 07-15-2006 16:56:14
I have the housings here from a TO 30 - also all the gears,etc if you need them and if they would fit!
John (UK)
07-16-2006 13:17:56
The Rear Axle housing from a 9N would fit but don"t use one as it is too light, in fact Ford fitted the Ferguson Rear Axle when they had problems early in production. A housing assy. from a TE or TEA will fit, they say that the TO30 wont fit(that is due to the different size diff and axle-shafts) but the gasket between the two halves is the same, so you could fit the whole rear end,from behind the gearbox, which is heavier built in the diff and axle-shafts.
Casenut
07-16-2006 13:50:32
 Re: TO20 rear differential in reply to John (UK), 07-16-2006 13:17:56
Thank you very much John. That is exactly what I needed to know., Casenut
