TO-20 Connecting Rods
Clint1
07-14-2006 15:31:56
I had a strange sound cominng from my engine yesterday after about two hours worth of mowing this is just after a engine rebuild so I took off the oil pan and a bolt broke on the number two connecting rod the only thing to be replaced is the bearing luckily but I need to know the hardness of that bolt if anyone knows, would it be a grade 8 or a grade 10.
gshadel
07-15-2006 18:18:02
 Re: TO-20 Connecting Rods in reply to Clint1, 07-14-2006 15:31:56
Clint, You don't hear of connecting rod cap bolts breaking every day. I recommend you inspect and retorque all of them to make sure you don't have any other clunkers in there. Manual says torque to 35-40 foot pounds. If the bolts were over-torqued at some point, they may be weakened/stetched now.
I know, not your original question. I don't know the grade, I don't recall the size bolts either, but... I have a handy-dandy torque chart here for grade 3,5,&8 bolts. I will rattle off some sizes and torques to see if that helps.
grade 5
3/8 bolt course thread - 35 ft lb
3/8 bolt fine thread - 40 ft lb
7/16 course - 55 ft lb
7/16 fine - 75 ft lb
grade 8
5/16 bolt course thread - 28 ft lb
5/16 fine- 30 ft lb
3/8 course - 50 ft lb
3/8 fine - 60 ft lb
hope that helps
George
