Eyebolt and Bushing for TO-20
Ron Lindquist
07-13-2006 17:55:23
Was told by the MF dealer in Antigo Wi that the Eyebolt is available for $16.00+ and the bushing is not availale in the U.S. !!!
part #'s: eyebolt 180 856 M91 bushing,eyebolt 180 859 M1
Also looking for the Hydraulic Lift Rocker---again not available in U.S. # 180 899 M1
If anyone know of a source, please let me know .
Thanks,
John (UK)
07-14-2006 09:41:11
 Re: Eye-bolt and Bushing for TO-20 in reply to Ron Lindquist, 07-13-2006 17:55:23
The eye bolt and bushing assy.is available from Sparex part # S61019. For the Rocker you can use Sparex S61643 from a Ford 9N plus a S61318 pin to replace the bush. The Rocker differs in that it has two positions for the Top Link, the normal one to use is the bottom one, the top position you would use for light Draft work where there was only little compression down the top link, being in the top position would make it more sensitive, if you don't need anything like that just use the bottom hole as normal.
mn.Chuck
07-13-2006 18:46:48
 Re: Eyebolt and Bushing for TO-20 in reply to Ron Lindquist, 07-13-2006 17:55:23
The "parts depot" in Chilton, Wi has the bush and
eyebolt for far less than the $16. 1-800-743-3768.
Any Equip dealer must order it though. They all
have an account there but few bother. These are
OEM Massey Parts. Chuck
Ron Lindquist
07-13-2006 19:58:53
 Re: Eyebolt and Bushing for TO-20 in reply to mn.Chuck, 07-13-2006 18:46:48
Thanks, Will give them a try in the mourning.
Ron Lindquist
07-13-2006 18:35:56
 Re: Eyebolt and Bushing for TO-20 in reply to John (Ohio), 07-13-2006 18:04:52
Tks, You must be a dealer ? Found web sight but could'nt go further. Got a local dealer I'll have to call tomorrow.
The catalog seemed for dealers only. Would be nice to see it.
