Think i'm missing an oil filter
Chuck NH
07-10-2006 14:19:49
Just purchased a TE-20 with the Z120 engine. Tractor looks and runs good, but I cannot find the engine oil filter. The oil pan has no access cover in the bottom like my TO-20, but it does have the rods running on each side of the oil pan. Was this normal not to have a oil filter? Any suggestions? The oil pressure is low at an idle (0 psi) but increases as the speed increases. Have not checked it with a new guage to make sure it's not a guage issue. Thanks for looking.....
Jeff-oh
07-11-2006 05:03:48
 Re: Think i'm missing an oil filter in reply to Chuck NH, 07-10-2006 14:19:49
"TE-20 with the Z120 engine"
Same engine as your TO-20... Same filter location. If you do not have the 6" diameter filter access plate on the bottom like your TO-20 then the oil pan may have been removed and replaced at some point. The side rods are a TE/TO difference, but are unrelated to the oil system.
Jeff
TE-40***
Chuck NH
07-13-2006 17:59:02
 Re: Think i'm missing an oil filter in reply to Jeff-oh, 07-11-2006 05:03:48
Jeff, Thanks for responding! I'm thinking that I will need the correct oil pan, the suction bell, and return line as well for my TE-20. Do you know if the Z120 was used in another application without a oil filter or maybe a remote mounted filter? I just think it strange this engine has no filter at all....
KGRIFF
07-14-2006 20:52:02
 Re: Think i'm missing an oil filter in reply to Chuck NH, 07-13-2006 17:59:02
I HAD ONE WITH THE SAME SITUATION. SOMEONE PUT A TO30 PAN ON IT.
Chuck Palmer
07-17-2006 09:22:09
 Re: Think i'm missing an oil filter in reply to KGRIFF, 07-14-2006 20:52:02
KGRIFF, What did you end up doing with yours? Did you put on the correct pan and if so, did you need to get the proper suction bell and/or replace the pump? Could a TO-30 filter housing be installed? Thanks for responding.
