TO30 block mounts broken
Stetson
07-10-2006 11:51:23
I have a T030 with an allied loader. The engine block front mounts have both been welded to fix cracks. Metal fatigue and the added weight no doubt caused the problem. The welds as I can see were made by someone competent. Good solid beads. However, the cracks are starting again. I'm not crazy about the mounting system used to fix the loader to the block. Manufactured by the previous owner. Not that there is anything wrong with that but I think any bracket would need to be made making sure stress is evenly distributed using as many mounting options as possible. I'm thinking there must be a bracket made by someone that I can use and modify. Has this problem been around for sometime since the first aftermarket loader came out for the Fergusons? If so what are some solutions used?
Thanks
