generator test
John in MS
07-06-2006 12:19:14
What is the best way to test the output of the generator on a 1950 TO-20?
souNdguy
07-06-2006 12:37:43
 Re: generator test in reply to John in MS, 07-06-2006 12:19:14
Put you're volt meter across a battery and fire her up. i fthe battery reads about 6.2v before cranking and about 7.x after starting , and at mid throttle.. then the votls are good. Your ammeter should also show a slight positive deflection to corespond to this.. etc.
You can full field your genny to get max amps as well, if you want more of a test. As well as trying a motor test..e tc.
Soundguy
gshadel
07-06-2006 13:39:42
 Re: generator test in reply to souNdguy, 07-06-2006 12:37:43
Just to make sure we are on the same wavelength, this info is for the original 6V positive ground system only. The voltmeter testing that souNdguy is talking about tests both your generator and voltage regulator working together, the regulator controls the generator output. If your voltmeter does not respond as souNdguy says, I recommend you check your ground conections on the regulator, and the back of the dash, and that all your wire connections are all clean & shiny, then test again. 6V systems suffer from corrosion problems more than 12v systems.
If you still do not get ~7v at mid throttle, your next step is probably to check just the generator. That is the full field test that souNdguy mentioned. Do that by running a jumper wire from the positive terminal (ground) on the battery, to the generator field(F) terminal with the engine running ~1/2 throttle. Check volts across the battery when you do that. Your volts should ramp-up to ~6.8-7.0, and your amps should ramp up to ~10-12. If it don't, your generator is suspect. If your intial volt check fails, but the full field generator test works, then your voltage regulator is suspect.
If you have had the generator or regulator off the tractor lately, you might try re-polarizing your generator before spending any money, just to be sure that isn't the problem.
George
