Stuck in Reverse
Drex
07-04-2006 07:19:29
While in reverse and backing down a small hill, I jacknifed my TO 35 right rear tire into the wagon when I hit my shaky brakes. After freeing the tractor, the stick is stuck in reverse and even with a fair amount of pressure and some sharp blows, will not come out of reverse. Anybody know any tricks? and yes fixing my brakes is next on the list, Thanks.
Cosmo
07-04-2006 07:42:31
 Re: Stuck in Reverse in reply to Drex, 07-04-2006 07:19:29
Remove the trans. filler plug to the left of the gear lever. With a big screw driver or small pry bar or similar inserted in hole you can slide the LARGE gear forward if in reverse or rearward if in first. Have the short lever in neutral to remove any pressure on the gears. I've done mine a few times. In the future try to exert downward pressure on the shifter when changing gears. Hope this helps. Regards, Cosmo
Drex
07-04-2006 11:02:26
 Re: Stuck in Reverse in reply to Cosmo, 07-04-2006 07:42:31
Worked fine, many thanks, except now I have to go back to work on the holiday - thanks again, Drex.
Cosmo
07-04-2006 11:43:30
 Re: Stuck in Reverse in reply to Drex, 07-04-2006 11:02:26
Most welcome. Glad to help. Cosmo
