Serial number
Boyde From Bram
07-04-2006 05:13:40
I have a TEA20 -85. I am looking for the serial number of the engine.
I remember reading that it should be on the block between the coil and the starter. I cleaned that area until it gleans. I cleaned the whole block on that side of the engine. I can not find any numbers or letters on the block.
On the other side behind the Zenith carburator is a series of numbers, that do not start with "SC". It starts with "OA123..." (I do not have it written down in front of me right now)
Where should I be looking?
Regards
Boyde
John (UK)
07-04-2006 13:14:46
 Re: Serial number in reply to Boyde From Brampton, 07-04-2006 05:13:40
It should be stamped into the block between the oil filler and the coil. It is stamped into a raised "ridge" that has been machined to give a flat surface
It may not be prefixed with SC at all, maybe just S, it will depend on how old the engine is. If you can't find a number in that location it is possible that the engine has had a new Cylinder Block fitted. Who ever did that should have stamped the number in the same location.
boyde
07-04-2006 14:31:56
 Re: Serial number in reply to John (UK), 07-04-2006 13:14:46
Thanks John.
I did clean and inspect that area, but not as diligently as between the coil and the starter.
I did not notice any flat area, but I will focus closer to that area.
Is the number cast in place or was it punched/pressed after casting?
I'll be back where I have the tractor this weekend.
Regards
Boyde
John (UK)
07-04-2006 17:27:18
 Re: Serial number in reply to boyde , 07-04-2006 14:31:56
it is punched in the block....if you email me at fergusontractors(at)tiscali.co.uk
so I have your email address I can send you a picture of what it looks like and where it is...John
