No power coughing and stumbleing. Got Her Fixxed
Griz
07-03-2006 12:29:16
My To-20 would do like so many To's, cough, stumble and loose power. There always seemed to be enough gas coming through the line; but, there really wasn't. I had a chunk of something stuck in the infamous sediment bowl shut-off intake. I tried to flush it. There is just too much crud. I'm thinking it could be an old cork gasket from the gas cap disentergrading. There was a screen around the intake; but, there was no top on it. I carefully bent the sides of the screen over, to seal it. Thought I had it made. Last time I mowed more coughing. A little ether spray got her back to the garage. Blew air up the line backwards and finished the mowing.
Today I fixxed her, I think. Took out the sediment bowl and replaced it with a fitting with a 1/4" barb. I soldered a piece of copper tubing inside the fitting and drilled a series of 1/8" holed in the copper tubing. I hooked up my filter and shut-off. I don't think it will ever plug up again.
Hope this will help you guy's with a similar problem.
