TO-30 Carb breather Assembly
Tighten-Them-Bolts
06-24-2006 02:10:43
Hello, I am missing the entire breather assembly down to the carb, I have found some replacement parts except for the filter can, Is my best option to look for this at a salvage yard or is there a after market one avaiable? Does any one have a photo of a complete installed system? I am a little confused on how it ties to the vent/intake thingy on the dash.
Jerry/MT
06-25-2006 16:22:58
 Re: TO-30 Carb breather Assembly in reply to Tighten-Them-Bolts, 06-24-2006 02:10:43
I measured the length of my TO-30 Air Ceaner and it's 11-7/8 to 12" in length, as close as I can tell without taking it out. The Sparex TO-35 A/C is about 2 " longer(13-7/8 "). Whether you could adapt it or not is an unknown. If I were you, I'd try looking for one in a salvage yard or on ebay. However, the rest of the parts should work for you. Good Luck.
Tighten-Them-Bolts
06-24-2006 19:24:11
Any help will be greatly appreciated, I havent figured out how they post pictures here either. Is this type a oil bath filter?
Thanks
Jerry/MT
06-24-2006 19:55:27
 Re: TO-30 Carb breather Assembly in reply to Tighten-Them-Bolts , 06-24-2006 19:24:11
Yes it is. The oil bath air cleaner was the standard of that era of machinery.
Jerry/MT
06-24-2006 13:49:20
Sparex has a filter that looks like it might be used on the TO-30. Its listed for the TO-35 after SN 204181 (Sparex P/N S.42747, Ferguson part No. 187118M1) and is 13-7/8" from the bottom of the oil cup to the top of the air inlet. I'll have to go out and measure my TO-30 to see what it's A/C length is. They also have a air cleaner tube for the TO-30 (Sparex P/N S.60074 181716M1) and the rubber inlet hose that goes from the dash to the air cleaner inlet (Sparex P/N S.42566 180362M1).
If these don't work, the salvage yards and ebay are potential sources for air cleaners. Be careful of ebay. Many times sellers advertise a part for a TO-20 that won't work on the TO-30 but they say it will. I'll get back with the length of the TO-30 A/C after I measure my air cleaner.
ronS (Utah)
06-24-2006 05:15:06
The connection at the dash is by a curbed rubber part called an "air inlet hose." Part # 180 362 M1. (Old part number was TO-9614) A little later this morning I will scan a drawing of the assembly, and send it to you via email. I am not sure how to post photos on this site yet. Good luck.
