TE20
uneven running at idle
Talf
10-13-2000 02:51:12
I use a TE20 at work, and after hearing a restored axample run realised that the one I use runs very poorly at low revs. The engine ticks over unevenly and there is a 'poofing' sound from the exhaust - misfire. I have a dwell angle meter, and wondered if anyone knows the correct dwell angle for the tractor. It is a straight pertol with a zenith carb and lucas electrics.
Anyone have any answers??
Cheers
Tex Ferguson
10-21-2000 07:55:01
 Re: TE20 - uneven running at idle in reply to Talf, 10-13-2000 02:51:12
Well, Talf, I would first check the plugs and points and timing -- maybe a simple ignition tuneup would cure the rough idle and give more power at higher engine speed as well. Might be a chipped or sticking valve or wornout camshaft. Be sure to post back on what you found out. Good luck! Tex
Big Talf
11-07-2000 15:28:57
 Re: Re: TE20 - uneven running at idle in reply to Tex Ferguson, 10-21-2000 07:55:01
Hey up talf hope you solve your little problem soon good luck son, if you need a hand, don't be scared to give your old dad a ring
Big Talf
