John (UK): FE-35 Perkins Diesel Wiring Diagram
Dean
06-21-2006 17:24:28
Might anyone have a wiring diagram for a FE-35 with Perkins diesel?
I recently discovered that the generator on this tractor is not charging. It still has the original Lucas generator and voltage regulator but the wiring has been farmerized.
I discovered one wire connected to the voltage regulator that is simply taped off. Both the armature and field wires are connected to the voltage regulator so I expect that this one should connect to the battery but am not certain.
Compounding the problem, this tractor was apparently built with neither ammeter nor charging indicator lamp.
Thanks, in advance.
Dean
John (UK)
06-22-2006 04:26:40
 Re: John (UK): FE-35 Perkins Diesel Wiring Diagram in reply to Dean, 06-21-2006 17:24:28
Do you mean an MF35 or an FE35, the FE35 only had a Perkins Diesel TA144 for export to France and Germany. It was fitted with a Standard 23c diesel until 1959 (166595)and then the 3A-152 Perkins for the rest of the world. They both had an ammeter fitted from new only the carb engines had a warning light.
I do have a wiring diagram no matter which, just let me know, but you will have to email me at:-
fergusontractors(at)tiscali.co.uk so I will have your email address, I can't send any attachments to you on here.
