TEA 2085 Bearing Summary
chuck130
06-21-2006 09:45:58
Compiled this list while I was restoring my '54. Use the numbers when ordering from a bearing supply house. Where 2 numbers given, one is for cup, one is for cone. 'T' = Timken brand. Thought it might be useful to you.
Description #
Clutch pilot 6203
Main drive pinion T15385
Mainshaft front T25877, 25820
Mainshaft rear T25877, 25820
Countershaft front T25877, 25820
Countershaft rear T25877, 25820
PTO shaft front 6206
PTO shaft rear 6206
Diff Drive pinion pilot H3773
Diff Pinion thrust ?
Rear axle inner T3984, 3920
Rear axle outer T3795, 3720
Front axle inner T15123, 15245
Front axle outer T09067, 09195
Front spindle thrust T126
Steering column T4CB 6
Water pump N3179V3
Distributor (Lucas) LJ � 2RS
Generator (Lucas) 6202
John (UK)
06-23-2006 12:38:02
 Re: TEA 2085 Bearing Summary in reply to chuck130, 06-21-2006 09:45:58
Being as no one seems to have thanked you for that Chuck I will.always useful to have....John
Al in BC
06-25-2006 17:37:24
 Re: TEA 2085 Bearing Summary in reply to John (UK), 06-23-2006 12:38:02
My Thankyou.s too.
Al in BC
