overheated oil line
jock
06-19-2006 18:22:28
I have a 1955(?) TO 35. The oil line running from the side of the block to the oil pressure gauge turns red hot after running for a short while. The line is clear of any obstructions but it doesn't look like there is any oil going through it. The engine block doesn't get that hot. Any help would be appreciated.
Thank you, Jock
John (UK)
06-20-2006 07:12:58
 Re: overheated oil line in reply to jock , 06-19-2006 18:22:28
It does sound like an electrical problem. If the ground from the battery is still attached to the Dash panel, then fit a longer Ground Lead and attach it on one of the starter bolts or close by anyway, that should cure it.
jock
06-20-2006 09:20:04
 Re: overheated oil line in reply to John (UK), 06-20-2006 07:12:58
Thanks for the advice. I"ve gone over just about everything else but a grounding problem never occurred to me. Thanks again.
Jock
RogerL
06-20-2006 04:36:11
Nothing to add other than it has to be electrical in nature. A bad ground somewhere. Check the condition of the ground from the battery, at both the battery end and the end that bolts to the tractor.
Only thing I can think off from the top of my head is that the battery is grounded to the dash, and the dash is somehow electrically isolated from the rest of the tractor except the oil gauge line. I thought this was all solidly bolted to the tractor but I suppose anything is possible.
RP2
06-19-2006 21:26:45
I'm not familiar with the TO-35 (I'm a TO-20 man) but if you are serious about it being actually glowing red hot then that sounds like an electrical fault. There shouldn't be any oil actually going through that line since it dead ends at the gauge.
I'd be inspecting the battery and charging sytem wiring. In particular this sounds the engine is grounded through that piece of tubing!
