More of a train than a tractor
Mike
10-11-2000 03:29:00
I recently got a 35 4 cylender running after rebuilding the engine. The problem is that it smokes like a train. I have ground that valves in. What could be the cause of this problem, any help grately received.
twopop
10-15-2000 09:49:40
 Re: More of a train than a tractor in reply to Mike, 10-11-2000 03:29:00
you might not be getting complete combustion yet because the rings arent worn in.did you have the injectors and injection pump checked or reset.the injection timing might be off slightly
Joe Ferguson
10-11-2000 04:00:02
Hi Mike
Is it a diesel or gas ?
Smoke is black with gas or fuel smell ?
Smoke is blue with oil smell ?
Smoke is white with anti-freeze smell ?
To long to explain all possibilities
Please give us info
diesel or gas and smoke color and smell if any
Good luck
Joe Ferguson
Mike
10-13-2000 02:37:22
 Re: Re: More of a train than a tractor in reply to Joe Ferguson, 10-11-2000 04:00:02
its diesel
the smoke is a light grey colour - it does not smell of oil or antifreeze. smells of diesel.
the strange thing is that it runs very smothley, at tickover and at mid range revs.??
Thanks for replying hope to hear from you again.
Joe Ferguson
10-15-2000 14:26:13
 Re: Re: Re: More of a train than a tractor in reply to Mike, 10-13-2000 02:37:22
Hi Mike
I agree with previous post it seems to be
combustion problem.
Lets begin by simplest things (just ideas)
How old is the fuel in the tank ?
If older than one year drain and put new fuel
What is the color of the fuel
Must be crystal clear or clear/light blue
If it is yellow (beer like color) it is no good
Disconnect air supply tube at the intake manifold
start engine ..still smokin ? if not air filter is clogged.
How old are the injectors ? Dripping instead of spraying injectors may cause
smoking. You can bring inj to inj/repair/rebuilt
shop they will check for few $ if correct you dont
miss anyting... .if defective a step will be done.
Be careful when reinstalling an bleeding them
do not expose your skin when you loose fittings
wear glove and safety glasses..to avoid high pressure fuel injection in your skin it may be very dangerous.
Is it a vertical exhaust pipe ?
If yes check if kids or somebody dropped strange
bodies inside and/or check for exhaust system
restriction..bent or squeezed pipe and ....
If you find something please let us know
it will be helpfull for all of us.
This is not an expert advice
Just few ideas
Good luck !!!
Joe Ferguson
