TO 20 distributor dust cover removal
steve andersen
06-16-2006 18:48:23
I've checked the archives..... not to explicit on the subject. would like to remove the distributor dust cover without destroying it....is there a secret???
thanks in advance
steve
Jerry/MT
06-16-2006 19:15:57
 Re: TO 20 distributor dust cover removal in reply to steve andersen, 06-16-2006 18:48:23
that's because there's nothing complicated about it. It just sits there. The distributor dust cover sits in place and is indexed by a notch in it. You just pull up on it to remove it. If it's a little tight, rap it gently with a piece of wood. Really, it's a no brainer.
steve andersen
06-17-2006 07:09:08
 Re: TO 20 distributor dust cover removal in reply to Jerry/MT, 06-16-2006 19:15:57
jerry:
It's been coerced with a wooden mallet rather fiercely.....guessing oxidation has a good grip on it. As long as you say it's just a drop in i'll stay with the oxidation approach.....thanks again.
Steve
P.S.my life has been nothing but no brainers.....with complications...
Jerry/MT
06-17-2006 09:33:34
 Re: TO 20 distributor dust cover removal in reply to steve andersen, 06-17-2006 07:09:08
Let's make sure we are talking about the same thing. The dust cover is a disk type device that sits over the part of the distributor that holds the points and condensor. It's below the rotor and under the distributor cap,and it's made out of Bakelite with a hole in it for the distributor shaft. If you break it, it can be replaced. Tap under the lip where it overhangs the points housing gently with a screwdriver and you wooden mallet in an upwards direction. I have never seen one that was on so tight that it could not easily be removed , but then again, I ain't seen it all. Good luck
