help ident. tractor
Enrique Dupuy
06-16-2006 10:05:52
I need identifi a tractor engine number Z120 24262
Chasis 14663 Ferguson. year and model please
mowr
06-18-2006 20:13:06
 Re: help ident. tractor in reply to Enrique Dupuy, 06-16-2006 10:05:52
From the info I see on this site, it looks to me like a Ferguson with an aluminum housing and a chassis serial no. of 14663 should be a 1947 TE-20.
John (UK)
06-16-2006 12:57:47
 Re: help ardent. tractor in reply to Enrique Dupuy, 06-16-2006 10:05:52
We need the prefix letters on the ident plate (alongside that number you gve)to tell us what it is, it could be either a TE20 (1947) or a TO20 (1950). Check to see what the gearbox housing is made of is it cast iron (TO20) or aluminium (TE20) Although it could possibly be a very early TE20 as they had cast iron boxes too. Are you in USA or elsewhere, if you are in Europe it will be a TE20.
Jerry/MT
06-16-2006 11:40:50
On the left of this page, you'll find a section called research & Info. Click on Serial Numbers and then follow the links to the Ferguson Tractors. You'll find that your tractor is a TO-20 and be able to identify the year made from the serial number which should read TO XXXXX which you'll find on the dash board above the steering wheel. A fella' named Jim in OH has a correlation of engine number versus year that can also be used to find the year of the tractor and I think it's located in the archives in this forum.
Jim in OH
06-16-2006 11:57:16
 Re: help ident. tractor in reply to Jerry/MT, 06-16-2006 11:40:50
Thanks, Jerry.. but it is just for TO-30s.. chart below since it is easy to reference...
third party image
