Camshaft Plug
oldgit
06-15-2006 20:42:34
I was getting every thing set to put my Engine back togather today when I noticed the Plug on the back where the camshaft goes was missing. I have searched online for the part (19 259) without any luck. Does any one know where to get one or what might be used in its place? also how do you seal it so oil dosent leak out?
Thanks,
Oldgit
Jim in OH
06-17-2006 15:08:36
 Re: Camshaft Plug in reply to oldgit, 06-15-2006 20:42:34
It is the "concave" type (same as Dome type) and I measure it at 2 1/8 inches in diameter... Jim
Jim in OH
06-16-2006 05:32:20
This is just an "expansion plug" like what is used for freeze plugs and plugging oil galleys. It should be available from most any auto parts store (example, NAPA) but you will need to know the diameter of the hole and the type you need. Also, they are available in different materials. I'd use steel for this application. I'll look when I get home, but I think that it is the "concave type" as shown here:
third party image
There is also the "cup type" as shown here:
third party image
What I do (for the concave type), is clean the hole, coat it with a thin layer of gasket sealer (oil proof and hardening), then seat and flatten the concave plug with a ball peen hammer... For the larger diameter ones, I use something bigger (like an old socket about half the size of the plug) between the hammer and the plug. A machinist will probably use a press. But I've only done a few so maybe the pros out there will have some other tips... Jim
Jerry/MT
06-16-2006 11:42:42
 Re: Camshaft Plug in reply to Jim in OH, 06-16-2006 05:32:20
Jim, How do you manage to post the drawings on this forum?????
Jim in OH
06-16-2006 12:11:56
 Re: Camshaft Plug in reply to Jerry/MT, 06-16-2006 11:42:42
Not sure what the question is... drawings (or anything) can be made into images just like pictures, then posting them is identical to pictures... In this case, I cheated, I didn't do any of that... I found images of what I wanted to show at another site, then just "pointed" to them instead of uploading my own.... If you are asking how I posted multiple pictures mixed with my text, I have posted the answer to that too.. See link... Hope that answers your question.. Jim
Jerry/MT
06-16-2006 19:26:10
 Re: Camshaft Plug in reply to Jim in OH, 06-16-2006 12:11:56
That' really neat. Thanks for the info. I'm somewhat computer literate but not as much as I need to be.
