TO-20 oil filter number
Bruc
06-11-2006 09:19:20
Got a TO-20 and dropped the oil filter out. Napa gold 1107 on the filter. Complete with a recessed area on both the top and bottom with a spring in there somewhere that also fell out.
Went to Napa, ordered a filter and the 1107 that showed up was flush on both ends with no obvious provision for a spring and no large "O" ring gasket.
What filter number do I need?
Thank you!
Bruce
nonac99
06-11-2006 12:34:43
 Re: TO-20 oil filter number in reply to Bruc, 06-11-2006 09:19:20
There is a lot of "back and forth" regarding this spring. Some say it is supposed to be there and some say it is not. I am convince that there is not supposed to be a spring in contact with the filter. The only spring the manual shows is up above that upside down soup can that you see up inside the oil pan when you drop the filter out. With the filter out you should be able to push up on this can and feel a spring pushing back. Do a seach for spring and/or filter and you will find dozens of posts on this subject.
Joe (IN)
06-11-2006 18:03:15
 Re: TO-20 oil filter number in reply to nonac99, 06-11-2006 12:34:43
Amen, brother!
bruc
06-11-2006 13:39:56
Since the spring is in there to begin with...
However, It is extremely possible the entire assembly was updated at some time so the new style filter was made to overcome the absence of the spring in the update...
I dunno, I am just lost and stumbling in the dark...Will do a search on the archives, Thankx for the info!
Bruce
