I'm not sure if my last post was the lost email John(UK) refered to or not... Since I did post a problem earlier today and didn't see it show up on the board, here it is again...I bought a TO-20 for parts (particularly the crankshaft) for fixing up another one. I'm having a devil of a time trying to get the engine split from the tranny. It looks as if the tractor was parked in a swamp for the last 30 years. The clutch assembly is very rusted and siezed. After much prying, pounding, wedging etc., I managed to seperate the engine and tranny about half to three quarters of an inch. It won't budge any further. I took the starter switch plate off so I could look (and pound with a rod) down inside the clutch housing. I can wobble the engine and watch the flywheel/clutch assembly move while the throwout bearing stays solid with the tranny shaft. So for my questions: Is there anything mechanically in the clutch housing that could have broke in such a way as to prevent the engine from seperating from the tranny? In other words, am I for sure just fighting rust or could there be something else? Is it possible to lift the engine block off the crankshaft without disconnecting the flywheel from the crankshaft? Is there anything I can do to allow the tranny output shaft to slide out of the tranny and allow me to seperate the engine with the tranny shaft attached to the clutch? Are there any other tricks (besides dynamite - yet) to seperating the engine? I'm afraid I might break the engine block if I keep pounding wedges down in there. Thanks much, Mike
