TO-20 Battery cover
Mike Noonan
06-07-2006 08:24:22
Would like to buy an original TO-20 Battery cover for my restoration. I would also be interested in a reproduction if available.
TO30to
06-11-2006 19:00:30
 Re: TO-20 Battery cover in reply to Mike Noonan, 06-07-2006 08:24:22
My To30 hasthis cover zlso the gas capit also has the gererator adjusting bolt with the 11/16 head
Mike Noonan
06-11-2006 20:21:20
 Re: TO-20 Battery cover in reply to TO30to, 06-11-2006 19:00:30
I don't suppose you are interested in selling the battery cover?
Phil(WA)
06-09-2006 23:01:37
Mike, guess no one is going to answer so will give you my take on battery covers. These seem to be fairly rare as some people found them a nuisance and removed them, others corroded especially the batt hold down frame which the cover was hinged to, so were removed for that problem. If you are really lucky, a salvage yd may help you. Collectors and restorers are most probably not going to have extras, as many people are looking. Of course, ebay is another spot to keep checking.And then you may only find the cover, but you can find a metal frame in auto parts stores that you can use to attach the cover to with some tubing and a hinge pin of some sort.
There was a try at reproducing them a couple of yrs ago but didn't work out.
Phil(WA)
Mike Noonan
06-12-2006 08:30:03
 Re: TO-20 Battery cover in reply to Phil(WA), 06-09-2006 23:01:37
Phil,
I thought I sent a thank you reply but I didn't see it show up so again thank you for help and info.
Mike Noonan
