TEA-2085 oil filter
Jeff Kohl
06-04-2006 08:08:25
Just bought my first Fergie - a 1952 TEA-2085. When doing an oil and oil filter change I noticed the replacement oil filter was about 1.5 inches shorter than the one that's in there now and about 2 inches shorter than the cannister itself. Looking at the diagrams, it's obvious that many parts are missing. I have only the cannister, mounting rod and spring that pushes up on the filter (no washers, seals, or gaskets). I have custom-made a washer to slide loosely over the rod and sit on top of the spring to hold the filter up in place. Does it matter if oil can flow out of the filter into the cannister between the washer and the rod? What will hold the filter centered on the rod? I don't want to reassamble this until I get it right. Should I be hunting for a complete oil filter assembly?
Cheers. Jeff
Jim W
06-06-2006 08:01:24
 Re: TEA-2085 oil filter in reply to Jeff Kohl, 06-04-2006 08:08:25
Jeff if you need a new assembly I am pretty sure I have one (or perhaps more) kicking around in my basement. You can contact me at grandfatherjim at gmail dot com.
Jim
John (UK)
06-04-2006 08:23:57
The usual thing that goes missing is the plate that blocks the end of the filter element, it sticks to the old filter and gets thrown out. If oil escapes like you say between the bolt (rod) then it is escaping unfiltered, it should be a reasonably close fit to the bolt so that any leakage is minimal.
If you email me at:- fergusontractors(at)tiscali.co.uk
I will send to the parts list for the filter so you can see what you are missing. Just let me know if the bolt through the oil filter goes through from the top or the bottom.
Jeff Kohl
06-05-2006 09:22:55
 Re: TEA-2085 oil filter in reply to John (UK), 06-04-2006 08:23:57
Thanks John. I'll send you the info.
Jeff
