Shifting Howard reducer
Bruc
05-30-2006 07:13:59
I tried to post this last night and it looks like it bounced to parts unknown...
So, long story short, Which way do I shift the Howard to disengage it so I can pull start a TO-20?
Thanks much!
Bruce
John (UK)
05-30-2006 13:14:57
 Re: Shifting Howard reducer in reply to Bruc, 05-30-2006 07:13:59
It should be in normal drive NOT reduction. Pretty sure it should be in the down position, being as I haven't used one for about 20 odd years I am relying on what memory I have left. But I think I am correct in saying that as when it is down in normal drive it very often got kicked into neutral and they though the clutch had gone...If you get it wrong it will just rotate the wheels in opposite directions as it will be too low geared.
Bruc
05-30-2006 22:42:39
 Re: Shifting Howard reducer in reply to John (UK), 05-30-2006 13:14:57
Thank you for the reply! I have a TO-20 that has both the Howard and the Hup. It came to me with a damaged ring gear and the wife wants to use it before I split the case to fix it all. So, I get to pull start it! I found a shifting diagram for the Hup but until now was at a loss for the Howard. Thank you once again for the reply!
Have a good one!
Bruce
jimNCal
06-03-2006 07:59:52
 Re: Shifting Howard reducer in reply to Bruc, 05-30-2006 22:42:39
EASE the clutch out when pull starting a tractor!! DON'T 'pop' it. Use 2nd or 3rd gear. Tractor safe.
