transmission oil
dan from bright
05-27-2006 05:47:18
i would like to know if i should use hydra tranz made by pennzoil in my ferguson tractor transmission
Paul in Ms
05-28-2006 06:55:57
 Re: transmission oil in reply to dan from brighton, 05-27-2006 05:47:18
Cheak the archives. This has been discussed in great lenght. GL
-1 oil is the only oil to use.
John (UK)
05-28-2006 07:21:08
 Re: transmission oil in reply to Paul in Ms, 05-28-2006 06:55:57
90W straight mineral oil is GL1 and you can use 15W-30 Multi-grade oil if you suffer from cold weather too, it wont get as thick as the original type when cold.
Barry from Stirling
05-28-2006 05:50:53
Hi Dan
Walmart carries the oil that you need, I get mine there all the time. Its around $50 for a 20 liter pail. Hope this helps
John (UK)
05-27-2006 12:09:58
Sounds too thin to me...from the name...is it a hydraulic oil, like you would use in a digger or hydrostatic transmission?? if it is, that is wrong. The oil should be 90W straight mineral oil or 15W-30 Multi-grade oil. You can get the 90W from NAPA part # 65-205 5 galls.
Jim W
05-30-2006 05:53:12
 Re: transmission oil in reply to John (UK), 05-27-2006 12:09:58
Dan,
If you"re in the Brighton in Ontario, don"t bother pursuing that NAPA number - NAPA in Canada doesn"t use the same part numbers as NAPA in the US. Go figure. I asked them and they didn"t even have a way to cross reference.
(Maybe they are still using the UAP numbers from before NAPA.)
I also got mine from WalMart (it"s called Tech 2000) but remember it being more like $30. Find the one that says it will substitute for MF1129A.
Jim
dan from brighton
05-30-2006 20:27:06
 Re: transmission oil in reply to Jim W, 05-30-2006 05:53:12
the reason i am checking is , i went to tsc and they called a usa guy and he said this was the one @ $30 .00 can. so ipurchased it
John (UK)
05-30-2006 05:58:15
That sound a bit confusing don't you think Jim? You would have thought they would have got their act together by now.
