rotary cutters
Jim Nye
05-27-2006 05:38:42
Marlowe wrote:should add make sure that the one you buy has a top link that is ridged not one that can move back and forth and the top has a hole for the top pin and NOT a slot...
Can someone explain why the top link should be ridgid, My 5 ft. ford cutter has a top link that slips back and forth in a slot,it works fine,what would a ridgid mount do for me?
Thanks Jim
John (UK)
05-27-2006 12:19:09
 Re: rotary cutters in reply to Jim Nye, 05-27-2006 05:38:42
If you read all of his posting you would see that he was meaning that the A frame should be fixed so that the tractor Draft control can be used to control the height of the front of the mower automatically, to do this there has to be some pressure down the top link and if the A frame is slotted it can move around without sending any pressure down the top link so it wont control the mower. If you work on undulating ground the mower needs to follow it to cut evenly all over the cutting width, using the Draft control will allow this if you use position control or height control chains and the front of the tractor drops then the mower front will rise, if the front of the tractor rises then the mower could dig in the ground. To get the same results as using the Draft control you would have to be continuously moving the Control Lever.
Jim Nye
05-27-2006 19:34:20
 Re: rotary cutters in reply to John (UK), 05-27-2006 12:19:09
Thanks John,So correct me if I got this wrong. My cutter has a A frame,at the top of this A frame is where the top link connects,this point should NOT be slotted if I want the Draft control to work correctly.I am not trying to make a big deal out of this but was just curious what the difference was between a ridgid and slotted mount. Thanks again.....
Jeff-oh
05-30-2006 05:41:34
 Re: rotary cutters in reply to Jim Nye, 05-27-2006 19:34:20
Jim,
I have seen three types of connections for the top link on rotory cutters.
1) the basic hole. Just like a blade, or plow. This is the rigid conection being discussed.
2) is the slot. A fwd-to-aft slot that allows the top link pin to slip back-and-forth as you mow. It tightens up only when you use the lift to pick up the mower.
3) (and most common) a rotating receiver. This is an added piece that is pinned to a standard round hole then the top link is pinned to it at another hole. This allows a similar motion to the slot.
In cases 2 & 3 you cannot create compression on the top link, thus you take the draft control out of operation.
HTH Jeff
John (UK)
05-28-2006 06:06:24
That is correct, it should NOT be slotted, the A frame needs to be rigid so that it can move with the mower and transmit any movement to the top link and then to the tractor, unless it can push down the top link it cannot send signals to the tractor. I have attached Marlowe's original post to this site, it fully explains how you can take advantage of the draft control of the tractor to control the mower....John
Posted by marlowe on June 23, 2004 at 16:01:09 from (209.103.204.81):
In Reply to: position control...chains?? posted by mr chapp on June 23, 2004 at 06:16:49:
dear mister chapp. i have sold and serviced hogs for years and see this all the time. PLEASE don't take this wrong but it's a real common mistake that they are not beening mounted right.i know what your thinking how hard is it to put a hog on a tractor and go cut some grass? but!! your hog has a tail wheel right? your tractor has 2 lower lift arms right? set your hog on a 4x4 so it is level lower your tail wheel so it's on the ground. now put your tractor on but[[[[ DON'T]]] hook up the PTO with tractor running put the 3pt. control lever in the middle of the range and turn your top link so it will get longer and you will feel you 3pt. raise just a little and the stop but when you make the top link long it will raise a little more that because the control piston under the set is being pushed in and that makes you 3pt. lift untill the pressure is releasted.with a little fine tuning and a little setting of the tail wheel up or down for the height of cut you want your hog will cut at the height you want. if you have ANY questions call me i will help you set it right 1-920-446-3296 your hog should not be hanging on the tractor when your cutting but rideing on the tail wheel and the 3pt. at a set height and that is controled by your top link. good luck and if you need help call .END
