thanks for carb advice...more needed on plow
George in MI
05-23-2006 07:19:26
I adjusted the carb as suggested and the tractor runs very well. Thanks.
I have another question re plowing with my TO-20. The plow is a 2 bottom MF. Viewed from the back, the point on the right side is lower than the one on the right where the lift arms attach. Since the right tires are supposed to run in the furrow, doesn't this really cause the plow to tilt to the right? Somehow it seems like the low point should be on the left side and the raised hitch point on the right.
The plow does not seem to go very deep, maybe 6-7 inches...what should I do to adjust that?
Regarding the top link, should that be adjusted so that the plow is level(front to back) when held just off the ground?
John (UK)
05-23-2006 10:39:52
 Re: thanks for carb advice...more needed on plow in reply to George in MI, 05-23-2006 07:19:26
The top link should be 25" centre to centre of the pin holes if the lower links are the original ones that are approx 32" centre to centre. You can level the plow with the levelling lever on the right side lift rod. Look at the cross-shaft on the plow, it has cranked ends, the one on the right should be the lowest one. Turning this cross-shaft will also alter the width of the front furrow, which should be the same measurement as between the front land-side and the rear land-side plates. When you have all this right and you start to plow, adjust the levelling lever up or down until the front furrow matches the rear one. You can check the depth of each furrow by measuring the depth just after the front plow body and the furrow wall in the rear furrow. This is where the 10" plow spanner was used, to set the plow and to measure the furrow width and depth.
Dick Kline
05-23-2006 09:18:17
I used to be good friends with district manager for IH and this was his system. Find a nice flat spot and cut some timbers to tilt the tractor as if it was plowing. In other words block up the left wheels the depth you are going to plow. That should be one half the sweep, 12" is 6", 14" is 7" and so forth. Now adjust your plow to sit level.
