PTO KICKS OUT
d.jennings
05-16-2006 04:32:20
I can engauge the pto, but while mowing it will sometimes kick out. How do I correct this is it just a adjustment or is there a part that needs replaced?
Bill - SC
05-16-2006 06:42:21
 Re: PTO KICKS OUT in reply to d.jennings, 05-16-2006 04:32:20
I had the same problem on my TO-30. (1)Try grabbing the PTO shaft and see if it will slide in and out. Mine moved almost 3/4 of an inch. Any movement over 1/8" is too much. There are a couple of circlips in The PTO hub that hold the bearing in place one of mine was completely gone allowing the shaft and bearing to move.
(2) There is a detent that holds the PTO selector shaft in place. As you move the PTO lever to engage and disengage you should feel a definite "lock" as you move the lever back and forth, if not detent may be broken and not locking shaft in place.
I would check the shaft first as it is the easier repair, good luck.
